Hesitation/flat spot
Hi all, I have a '97 XJ6 4.0 which I have just bought. It has a flat spot/ hesitation when pulling away from junctions when warm. It is fine when cold & six air pump is running. Someone has fitted a replacement airflow meter & I tried a throttle body (pot luck) but it is still the same. I was debating a dead oxygen sensor (as these are overridden when cold start injector & pump run I believe ) & wondered if anyone can throw more light on this & point me in the right direction for tech data too.
Thanks in advance
Thanks in advance
First thing is WELCOME aboard.
Please do your intro in the "New members area" when time permits. It keeps the Moderators all warm and fuzzy, and is a good thing to do.
Many items come to mind, some you have attended to.
The rubber bellows trunking thing from the airflow meter to the throttle body can/does split with age.
The TPS {Throttle Position Sensor) under the throttle body is a prime suspect.
The CTS (Coolant Temp Sensoe) is also a suspect.
We dont have air pumps or EGR, so NO help with that nonsense.
I also throw in this one, coz I can.
Is the engine hesitating, OR is the transmission slipping??. How long since the trans fluid was refreshed??. The hesitation factor is very similar and takes some sorting sometimes.
Hi thanks for the comment. I will reply to new members when I get to a computer. I am on mobile via app & looked but could not find how to do this.
The throttle position switch was also replaced with second hand body (although condition not known) the fault can be septic acted stationary so in theory should eliminate transmission & also changes up & down cleanly.
Thanks for the input though ,oh & the bellows are good too
Gotta admit I really don't know where the OBD socket is on your car, since your steering wheel is on the "wrong" side! On mine, the OBD socket is at my right knee when I am in the driver's seat.
If you have a code, the engine diagnotic lamp (CEL) should be illuminated on the instrument panel.
The OBDII seems to be very hit or miss on the MY95 cars
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Great thanks, diagnostic plug by my left knee (should have looked first as it's obvious) just read the codes & as mentioned no light on but had p0101 & p0102 stored airflow faults they both cleared & it now idles better but still hesitates pulling away. Someone had fitted a replacement airflow meter in the past so may be old codes.
I noticed when revved to 2500 rpm data showed 18% throttle pos & 12% at idle. That doesn't sound right to me but again has has pos switch changed too
