high idle no codes
That makes sense. When you’re engine is cold, it runs off of a preprogrammed air/fuel map until the engine is warmed up, then it switches to various sensors to tell it how to adjust the air/fuel ratio.
What is going on sounds like a vacuum leak. Air is getting to your engine which is coming in past the MAF sensor. Can you check around and see if any hoses have come loose?
Sheff928 (09-27-2020)
I agree with Vee. The high idle issue is a recurring theme with these cars, and you will find a wealth of material in numerous threads in this forum. You havent mentioned whether your car is supercharged or normally aspirated, and whilst I have yet to see an idle issue attributable to the supercharger, its assorted plumbing makes tackling idle problems much more difficult.
