high temperature xj6 1995
Guest
Posts: n/a
Good day
I am planning to buy a Jaguar XJ6 1995 with 85000km only ,the owner informed me that the car indicate high temperature from time to time for the past 6 month, he said the water ok and everything ok .
Kindly can you please advise if this could be a serious problem, because I love to buy this car, what I need to check ?is it a good deal, price 4000$
Regards.
Regards.
![](https://www.jaguarforums.com/forum/images/kirsch/misc/progress.gif)
Received 10,876 Likes
the overheating itself may not be a huge issue, but if you do not address it immediately, it will cause huge problems, like warping your head.
because yes, it is uncommon for these cars to overheat, but when they do, it only takes a second to pop that head, and you might not see signs for months.
but as a precaution, flush your coolant, change your thermostat, and ensure proper operation of cooling fans. if not, check the wiring and connections, & you may end up having to replace the cooling fan control module, which is a big fat white relay that is mounted up under and behind the left side of the bumper.
rusty37
04-05-2020 07:40 PM
