horrible fuel economy.
Old 09-30-2022, 09:59 AM
Spud Maat's Avatar
Originally Posted by Parker 7
More words in the edit above , thinking a bit for a different way to understand , My training was as an engineer
yeah i can tell.
its good and its great to get a full understanding, and i really do love the indepth.
and the more i begin to understand the more that it all makes sense.
i just find it difficult sometimes to place the specifics into the practicality of what it means and what it actually does.
it would be like if i started talking to you about the science of coffee roasting.... lol...
  #82
Old 09-30-2022, 10:17 AM
Jagboi64's Avatar
Received 3,225 Likes on 2,121 Posts
Originally Posted by Spud Maat
just a thought on that note, could a crankshaft position sensor cause a high idle? Or is that more likely to cause misfires..
If it fails, it will more likely just stop the engine. Your higher idle may be an idle air valve that is gummed up with some carbon or other gunk ( note highly technical term!) and it can't move as much as it should to close off the bypass passage.
  #83
Old 09-30-2022, 10:23 AM
Spud Maat's Avatar
yeah planning to give the tb and associated bits a clean on the weekend.
  #84
Parker 7's Avatar
Received 1,012 Likes on 848 Posts
Someone a few months back cleaned the EGR valve / poppet and recovered the idle
On a ELM 327 this shows as EGR _ Error with a target value of 0 %
The IAC valve does not have a position sensor to compare the commanded position to the at the moment position
  #85
Old 09-30-2022, 10:28 AM
Spud Maat's Avatar
no egr over here.
egr is only US not ROW if i am not mistaken
Parker 7 (09-30-2022)
  #86
Parker 7's Avatar
The IAC valve has bolts that break off so heat is required , loctited 5..5 or 6.5 mm odd size
Do not remove the TPS from the TB , you don't want to lose the fine adjustment
  #87
Old 09-30-2022, 10:37 AM
Spud Maat's Avatar
The IAC valve has bolts that break off so heat is required , loctited 5..5 mm odd size
for now i will just take the tb off, clean it all and put it back on.
sounds like a potential PITA to remove and replace the iacv so i will just try and clean it while attached atm.
and will take note and not remove the tps.
overall it feels to me the car is running well.
except for the high idle so i don’t want to mess anything up in the process of chasing it down.
fuel economy has improved and remained settled now it has been a few weeks since replacing the O2 sensors.
it is currently sitting at avg 13.9 L/100. That is with driving to and from work every day with a combination of motor way and regular driving.
not heavy traffic stop start.
so much happier.
The following 2 users liked this post by Spud Maat:
Bill Mac (09-30-2022), watto700 (09-30-2022)
  #88
Old 09-30-2022, 10:47 AM
Parker 7's Avatar
There is the precaution to not get cleaning fluid past the IAC valve seal and into the stepper motor
The newer IAC valves which may include yours when the car was produced may have the improve Teflon seals
So bottom line keep the IAC oriented to not have fluid draining down into the IAC stepper motor
With the IAC connector better exposed this would be a good time to check with a meter to ensure you don't have a " open leg " that would prevent the valve from settling down to the correct almost fully closed commanded position
  #89
Old 09-30-2022, 07:51 PM
Bill Mac's Avatar
Received 1,096 Likes on 645 Posts
That figure of 13.9 L/100Ks is about what I see in around town running, or roughly 20 miles per imperial gallon or 16&1/2 miles per US gallon
I usually see between 9 and 10 L/100Ks on highway driving on round trips of 300 to 400 Ks.or 30 to 27 MPG (Imp) or 25 to 22 MPG (US)
So apart from the high idle I think you are now running about standard fuel consumption figures.
Old 09-30-2022, 07:54 PM
Spud Maat's Avatar
thats great to hear. So o2 sensors were certainly the biggest culprit of my issues.
she is feeling pretty nice to drive.
just installed andy bracket like 5 mins ago so am really interested to see what changes that brings.
  #91
Old 09-30-2022, 08:59 PM
Spud Maat's Avatar
So i have attempted to take the air temp sensor from the elbow to clean it.
i started to undo it and it unscrewed a little but I can’t remove it.
i can’t remove it or screw it back down.
all that happens now is it turns and turns turns.
there is a little gap now
  #92
Old 09-30-2022, 09:22 PM
Spud Maat's Avatar
Does this look right?
Full trottle (before engaging kickdown) should sit about here (see pic #1)
and then after engaging kickdown should push that bit further and push on the vacuum advance a little?
  #93
Old 09-30-2022, 10:31 PM
Jagboi64's Avatar
You can see in the second photo where I have added the arrow that the throttle has moved around to the stop. That is full throttle when it can't rotate any more. In the first photo you can move the throttle quite a bit more. Can you rotate the throttle to the stop by the pedal alone?
The vacuum capsule is for the cruise control to actuate the throttle.
  #94
Old 09-30-2022, 10:56 PM
Parker 7's Avatar
Something I noticed in your pic is another marking of M / A , different then the marking on the throttle cable outer sleeve position fixing bracket
Something that always bothered me was the master brake cylinder vacuum line banjo fitting on the intake manifold
This relates to your idle
  #95
Old 09-30-2022, 11:13 PM
Spud Maat's Avatar
It may look like that but at that point the butterfly is fully open.
and on the torque app when i push the pedal to the kickdown switch it reads 90% and when i push it that little bit extra and click the switch it reads at 100%
So yes. The pedal does fully activate the throttle.
gear shifting down is happening before kickdown is engaged
what has got me now tho is it appears to not be entering closed loop running mode.
rpm seems the same at cold start and when hot.
torque is reading 80c
whichbis too cold, but removing one of the sensors i get a coolant temp reading of around 90.
now this is a new temp sensor so i would assume it is good, but the problem i have right now is i cannot remove it.
when try and undo it the plastic fitting just spinning and spinning whilst the actual sensor is not undoing.
i don’t know of the sensor is giving the incorrect reading or the ecu is not showing the data correct.
but it does appear to not enter closed loop hot running mode
i have also noted that the coolant tank temp is only kind of warmish. So does that indicate improper flow?
  #96
Old 09-30-2022, 11:35 PM
Spud Maat's Avatar
not sire exactly what the a/m is there for in that one.
are you implying that a possible vacuum leak there?
  #97
Old 09-30-2022, 11:41 PM
Parker 7's Avatar
You can wiggle it from side to side so it's not the most confidence building
On the subject of that line is the possibility of a leak in the brake booster diaphragm that nobody discusses
  #98
Old 09-30-2022, 11:55 PM
Parker 7's Avatar
  #99
Old 10-01-2022, 12:06 AM
Jagboi64's Avatar
No, the coolant doesn't flow through the tank. It's purpose it to be a reservoir and allow air bleed from the system. I doubt your vacuum line fitting is a source of a vacuum leak, they are usually pretty robust.
  #100
Spud Maat's Avatar
While cleaning the little clear plastic window brok off of here.
i am not sure the best way to fix it.
i had some “form-a-gasket sealant” around so put a but on it and stuck it back on. Not sire if it will work or a better adhesive will be required.
Quick Reply: horrible fuel economy.
