Hot supercharger? intake temp readings
For the past few days I've had my supercharger belt taken off since I think my rear bearings are shot. So I realized when the blower isnt being used my intake temp readings have been reading at around 100 degrees or so with an ambient temperature of 80 degrees or so.
Today I hooked up my belt again and drove the car for about 10 miles and my intake temp readings are back up to 210 degrees.
Is there a way to flush engine mounted intercooler? or does anyone know what my problem could be?
My first thought is that its no wonder that the rear bearings are shot if you have been running the system with 210 deg intake temp. Would first hand suspect a defective electric water pump or air trapped around the impeller.
At an ambient temp 75F I usually see the IAT at something like 85 – 90F, with more inspired driving maybe 100F.
That is however with an upgraded system, pump and radiator.
Jan
Jan
Jan
Jan
I assume the higher flow Bosch pump?
I should probably have mentioned that my XJR6 engine is transplanted into an series 1 XJ6, so lots of things are certainly a bit different. The radiator that is used for intercooling is a junkyard find, think it was from a -94 Honda Civic. There is also an extra electric fan in front of it that can be engaged when needed. And the pump, yes its the Bosch 0392022010, better pressure and flow. Used for the Mercedes AMG etc.
The ic cooling system is totally separated from the engine cooling. Dont know how it is on the X300 but cant imagine that the construction permits hot engine coolant to mix much into the intercooling. A common expansion reservoir connection at most.
If the pump is tested ok I would next simply try to flush the separated ic and ic radiator, one at a time with a garden hose and also in different directions.
Jan
Jan
Jan
Jan
I did put a mechanics stethoscope to the pump and I hear a faint whine (like the pump is trying to turn but it can't)
I guess next step is to try and see if there is an air bubble caught in the lines right where the pump is located.
OkieTim
09-08-2015 04:48 PM
