How do I reinstall the smaller sunroof trim panel? - RESOLVED
By the looks of it the panel is supposed to sit in the drain channel guides but I can't seem to put it in.
Do I need to go from the back to the front? But that way the metal piece going across is blocking me. Going from the top seems impossible.
What should I do??
What should I do??
Last edited by GGG; 08-17-2021 at 07:58 AM. Reason: RESOLVED ... in more ways than one
The following 2 users liked this post by JezuzNoChill:
Cafcpete (08-17-2021),
motorcarman (08-17-2021)
I figured it out and might post a video in the next few days explaining the process for anyone else that might be doing the same. Also I wanted to ask you @motorcarman since you've repaired so many of these sunroof. Is it normal for one side of the mechanism to sit a bit lower than the other side when in the tilt position? The sunroof works fine.
Also where do I install this spring?
https://photos.app.goo.gl/xci1gsJaGXCXxiGA9
The interior trim panel need to sit parallel to the steel sliding roof.
The spring steel 'hooks' on the panel sometimes get bent and will not engage the mount points.(needs adjustment)
Just use the flat palm method of pushing the interior trim back out the tilt opening and try to get it lined up correctly.
PUSH UP and forward to engage the spring 'clips' back into the mounts and let them 'snap' into place.
Parker 7 (10-01-2021)
https://photos.app.goo.gl/ADT1imhEVqbWdPaa9
caldercay
10-24-2011 10:47 PM
