How do XJ6's die? What is X300 Kryptonite?
Received 10,944 Likes
My *impression* is that the OBDII improved somewhat in 96 and 97....but I don't have anything concrete to back that up.
I will not be getting this thing serviced at a dealer. If this is likely needed, I need to officially give up on owning a Jaguar...which I hope not to do.
This was one factor (or several) that entered into my decision to go back to an older model.
I am about to see if the need for dealer programming black-lists it or not, but I haven't read Doug's response yet because I saw yours and it pissed me off. If a group of vehicle owners teaching another person about mechanics and market factors related to that vehicle before he buys one is not due diligence, then what do you suggest I do? Do you know of a psychic vehicle advisors I can rely on? Can I pay with a credit card over the phone?
aholbro1's list of things that a regular DIY OBDII scan-tool wont do for this car is the same as with almost every other vehicle. I have a mid-level diagnostic tool that theoretically does this on most vehicles (It did on the XJ8).
My tool will not do the O2 sensor orientation. I dont believe anybody's will. That is not mainstream. I assume dealer only (or privately owned dealer tools at a niche shop perhaps). After reading up on it briefly, I would consider it unavoidable if needed and it is likely soon necessary on a 100K Jag. So how much does this cost? The Jaguar dealer in Frederick closed, others are maybe an hour drive. I am guessing not something that is only an hour labor though? I would think the dealers would back their products and be reasonable on price, but was it you Doug that said you were even turned away due to vehicle age? If anything turns me off to this Jaguar and all others ever, it would be a dealer refusing such service when needed.
Are TPS and IAC reorientation necessary as well or is this just a code-clearing issue? If I had to do one, I would go ahead and get them all. This is one time that I would be willing to fix what i'snt broken, and I usually ride it until the wheels fall off.
Received 2,263 Likes
#32
Lady Penelope, your assistance included:
1. A description of Nikasil problem in V8 jaguars and a diagram of commercial fuel refining in a post about AJ16 drivetrain concerns.
2. An offer to decode the VIN of my at the time already sold XJ8 to see if it had a six cylinder in it or not. (As if the badging wasn't enough, the motor cover said so, exhaust ports are visible, and the lack of hood as in the photo allowed easy access to check)
3. You provided grossly incorrect information about how to sell stuff on eBay.
4. Threw my first thread on this matter entirely offtrack by suggesting that my X308 was available for dumpster diving.
5. You did help me reiterate the point that my previous Jaguar drivetrain was worthless, after I clearly stated it had been sold as scrap metal anyway.
Its too bad you couldnt hang in here and provide a little more insight.
#33
An eBay search shows multiple listings for 95-97 ECU units, do they have this wrong if the 95 is different? I also saw a repair/exchange service for the ECU for around $300, but I am pretty sure this is nothing to do with what I am being told about, as I saw this for the XJ8 also.
Indirect answer as I haven't looked into the ECU part numbers, but you will find the following site invaluable in researching part numbers, part number cross references by VIN, trim level and region, and diagrams.
https://www.jaguarclassicparts.com/u...-xj-x300-parts
Also, AFAIK there is no ECU and other module reprogramming/reflashing available for the X300 from the dealer. Any updates to the ECU such as the EGR recall provides new ROMs that must be physically changed.
The various ECU, body control, seat, etc modules are pre-programmed from the factory, and even if they were reprogrammable years ago somehow, I've found that many dealers do not have specialized knowledge or much experience working on the X300 anymore unless they have an "old timer" in the garage. Jaguar of Cary has such a guy, and they give all "old" Jaguars like an X300 or X308 to him
The only person I know of that can reprogram portions of an ECU is XJREngineer (Andy) on this forum, who was an engineer at Jaguar when the X300 was being developed.
But there are some reset functions that can only be done by the dealer, unless you have the dealer diagnostic software, such as TPS reorientation, etc.
Fast71SS (05-06-2017)
#34
1. Base idle adaptations reset
2. TPS reset
3. Oxygen sensor reorientation, but this is the least important of the three.
If you don't have access to someone you can get to, to perform these tasks, then you may have issues with the car that cannot be resolved any other way. There's no amount of disconnecting power, or replacing parts that will solve your problem. You need to find a shop that can help you if you're serious about acquiring a car with an AJ16 engine.
A mongoose can perform only tasks 2 and 3, and unfortunately the only one that you absolutely need is #1. There are work arounds for the other two, but not for #1.
The following 3 users liked this post by Vee:
#35
I think I have V131 of the SDD. Whatever is the last version that doesn't need an internet connection.
#36
If I go with the plan of replacing all these sensors and have all the computerizing done at one time...I will be good to go for a long time before I have to seek additional computerization...right? This seems to be a do it and its done type of thing. Am I right on this?
If I buy the car and wait for one of these things to go bad, will I be able to drive it to the place to have it done? Will I be able to drive it around for a month or two with it running poorly while I save the money for the computerization?
What does WDS mean?
What does WDS mean?
#37
ebay is your best bet here. You'll want:
1. PDU
2. Genrad 3500, or WDS
3. Genrad GDS500 or 510
4. VCM I, not II
5. Mongoose
there are very well researched threads under the General heading. Go there and you will learn a lot about these devices.
the last two have clones available for purchase, they tend to be less reliable than the real deal.
The PDU is the only equipment currently confirmed to be able to reset idle adaptations. I am currently working on restoring a WDS, so I'll be able to tell you whether it will do it too. I have never seen a confirmation that the Genrad 500/510 can do it, although I believe if the 3500 can, the 500 can too. I don't know if the VCM I can do it, it's doubtful. Lastly, I can confirm that the Mongoose cannot.
all of the above equipment can do the oxygen sensor reorientation and the TPS setup. Unfortunately, those can also be fixed without the computer, although it does speed things up.
The base idle reset reset is the holy grail I am chasing.
1. PDU
4. VCM I, not II
5. Mongoose
#38
Correct. The Mongoose canNOT do a base idle reset. I've tried it with multiple different IDS versions.
Jagboi64 (05-09-2017)
#39
Car should never not be driveable. Rough/high idle and some stalling at stop lights is probably the worst case.
i don't know what causes the sensors to need adjustment. It doesn't happen often, I suppose if the car is not driven for long periods of time, like years? Also replacing TPS and IACV could require a computer reset, although not in every case.
What does WDS mean?
What does WDS mean?
Fast71SS (05-10-2017)
#40
1. PDU
4. VCM I, not II
5. Mongoose
1. PDU
4. VCM I, not II
5. Mongoose
any further info the WDS and idle adaptation??
