How does the Memory option work
Hi guys
Its great having this forum and I would really appreciate some wisdom from the knowledagable.
I have just recently purchased a 1997 X300 and am sorting out a few minor electical things.
I am not entirely sure how some things are supposed to work and they appear different to the driver manual and I am not sure if its a "fault" or a "build change".
I don't have a Jaguar service centre where I live so have to use a local general garage and would like to be able to give as much info as possible before I give them the car.
Michael
1: The memory function .... in the manual and new owner video it says that a light is supposed to come on in the memory switch when you press it and then, when you push buttons 1, 2 or 3, you will hear a beep.
I am getting no light or beep but the memory is working.
Should I have a light and a beep?
2: While the memory is working for steering column and mirrors it is not working for the seat position. What would be the most likely cause of the fault and the best place to start looking.
3: The passenger seat back works most of the time but, intermittantly, it doesn't respond until I do something like tilt the seat then it works again. What would be the most likely place to start looking for the source of this intermittant fault.
Any help or advice would be greatly appreciated.I am getting no light or beep but the memory is working.
Michael
rommel (11-21-2010)
Unable to open Bob's PDF files
Hi,
When I try to open Bob's files, I get an error message:
vBulletin Message jc2161, you do not have permission to access this page. This could be due to one of several reasons:
- Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
- If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
philwarner
09-05-2015 10:05 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
