How to remove chrome covers from rear door ashtrays?
Correct on both accounts:
1) The chrome cover is just glued on, and over 20ish years tends to finally fall off. It probably slipped inside the door panel, or may be under your seat. Regardless of finding your original or one from a donor, you can just glue it back on. It has little locating pins so there is no risk of misalignment. A really easy fix.
2) To remove the switch and ashtray assembly, just pry off the vinyl cover at the base (inside the door "pocket") and behind that is a screw. Loosen the screw, then the whole assembly lifts out.
deckwith
04-17-2018 03:15 AM
Jagman04
07-03-2010 02:38 AM
