How to remove fuel injectors?
Received 13,255 Likes
Hi ocean_view,
You can depressurize the fuel system by first removing the fuel filler cap to relieve any pressure or vacuum in the tank, then remove the fuel pump relay, start the engine and let it run until it dies. Disconnect the negative battery cable before proceeding to remove the fuel rail and injectors. A little fuel will spill out when you disconnect the inlet hose and Fuel Pressure Regulator (FPR), so stuff an old towel under each fitting before you loosen it.
The fuel pump relay is in the trunk fuse box - it's location is shown on page 26 of the Electrical Guide (page 27 of the .pdf file), which you can download here:
http://www.jagrepair.com/images/Auto.../jagxj1997.pdf
Cheers,
Don
MountainMan (05-04-2015)
Charlene n John
09-28-2015 06:01 AM
