How To Replace Front Shocks ( AfterMarket)
Old 09-11-2015, 10:16 PM
al_roethlisberger's Avatar
Can anyone verify the torque value for the bolts for the shock install, top and bottom?
Old 09-12-2015, 02:22 PM
JTsmks's Avatar
Originally Posted by al_roethlisberger
Can anyone verify the torque value for the bolts for the shock install, top and bottom? .
I used the German setting on the bottom "goodntite" 😉
Old 10-05-2020, 10:42 PM
LouieXK's Avatar
Alternate method of removing lower shock bolt
That lower bolt will trip you up - big time.
After trying to knock out with sledge / air hammer / electric hammer / torch, also using WD-40 / Kroil / PB Blaster, and MUCH time, this bolt just would not budge.
It was rusted in place to the inner part of the bush
Sawzall made quick work of shock tab, then a handheld hacksaw blade cut into the outer shell of bush, then tapped out with drift.
The new bush must be tapped into place or with a bolt and washer arrangement as mentioned in other posts -- only can be pressed in from back to front of axle.
The following 2 users liked this post by LouieXK:
Don B (10-06-2020), SleekJag12 (10-06-2020)
Highhorse
06-15-2024 03:51 PM
RaceDiagnostics
01-15-2022 10:01 AM
anjum
12-06-2016 11:40 AM
RaceDiagnostics
08-23-2015 04:48 PM
vandenplas408
12-11-2014 10:59 AM
Quick Reply: How To Replace Front Shocks ( AfterMarket)
