How should i go about do this job VDP 96 tie rod ends
so i just
disconnect the neg battery terminal
loosen Locking nut to tie rod end but do not move it really since
new tie rod need to set in same spot as old?
take nut off the tie rod end press the tie rod end out
screw new one up to locking nut and lock the nut onto the old spot
then place the tie rod back into suspension and tighten the nut on top?
this seem pretty easy and straight forward
i will make a pic tutorial asap once i do this.
i already have parts just need any tips/ pointers
so i just
Then unwind the tie rod end from the tie rod. To be safe I like to count the number of turns. Then screw on your new tie rod end, it should be the same number of turns that take it up to your mark. Then fit the end into the knuckle and tighten the top nut and the tie rod end locking nut. Done.
aholbro1
08-05-2021 05:02 AM
Dickie_L_J_O
09-13-2015 07:44 AM
