How to slide the front bumper forward?
One of the plastic slide plates that supports the wrap-around side of the bumper on my car was broken in a previous owner's accident. They replaced the bumper and screwed up the wiring in doing that but did not replace the broken bumper support carrier on the passenger's side of the car. I got a used one but in looking at this morning I don't think I can change it without at least partially removing the front bumper. Can anyone give me some short directions on how I can slide the front bumper forward just enough so I can replace this side support bracket?
Thanks in advance.
Steve
Thanks in advance.
Steve
Nevermind, I figured it out after sliding under the front of the car and seeing the two big bolt heads under the front edge of the bumper.
My problem now is that I got the slider bracket installed but the bumper on that side of the car has a huge gap at the back edge of the bumper where it meets the bottom of the fender just ahead of the wheel. I tried adjusting the slider bracket all the way up but it was already at the top edge of it's adjustment.
I will take a photo of this tomorrow to post here.
Grant Francis (10-23-2016)
Hey there Jensen Healey;
Don't know if this will help, but I just took off the front bumper from my 1996 XJR. I ripped the under cowl with a high curb (darn).
Here is a picture of one of the adjustable nuts, that one of the two bumper bolts go into. Maybe some sort of adjusting might help with what you want to accomplish?
Sure is easy to get off. Took me no longer than 1/2 hour and that includes learning what to do. Could do it in 15 minutes easy if ever needed to again (hopefully not).
Just waiting for the glue to dry on my under cowl so I can touch up paint and bolt back on again.
Sincerely ... Grant from Sunny Peachland in the Okanagan Valley, British Columbia Canada.
