HVAC control panel is loose
My HVAC control panel above the ski slope is loose so it falls back an inch or two until it stop against some structure behind it. The radio and clock modules are secure, however, so it's just the HVAC controls unit that's loose. I figure maybe the two top bolts have come loose.
Can somebody describe the easiest way to re-fasten the unit?
Received 10,920 Likes
It's screwed (from behind) onto the same frame that holds the radio and clock.
Somewhere in one of the "sticky" threads at the top of this section is a good write-up on radio removal. Follow those instructions and you'll be 98% on your way to reattaching your climate control panel :-)
GatorJoe (01-21-2013)
Poet
10-06-2015 09:40 PM
philwarner
09-16-2015 10:40 PM
