I think I'm going crazy
Hey Guys, I have a 95 XJ6 with a dead battery. I have been looking and looking for the positive connection in the engine comparment to jump it but can't find it for the life of me. I thought it wassupposed to be on the firewall, at least that's where it was on my 94 XJ6. Can anyone give me an exact location for it?
RE: I think I'm going crazy
Connect the positive end (red) clamp of the jumper cab directly to the positive terminal ON the battery, rather than a remote terminal.. but DO NOT connect the ground (black) clamp directly to the battery.. connect the ground to any unpainted/bare metal connected to the body or the frame of the car.. Hope that helps, Eric
Received 2,193 Likes
Thanks for the replies Eric and Brutal.
Eric, I'm sorry I wasn't a little more detailed in my post, because the problem is that I can't get at the battery. It's electronically locked in the trunk.
Brutal, I was looking at those studs but the wires leading to them are black so I wasn't sure. I'll try them this evening when I get home from work and let you know how that worked.
Thanks again guys, I really appreciate it.
Received 10,952 Likes
