I want to tow a trailer with my 1995 XJ6 - Bad idea?
I need to periodically tow a trailer with my 1995 XJ6-L VDP. LIke maybe once every 2 months.
It would be a 5x10 cargo trailer, curb weight around 1300 lbs, and I might load it with 500 pounds of gear, max.
This will be for short runs (<20 mi. one-way) around town and I can happily avoid steep grades.
Is this a crazy idea?
I remember seeing int he manual for one of my jags a comment about towing... but con;t find it. Online, the specs stuff I find just leaves 'towing weight' empty or N/A
I did find a hitch package online: Jaguar Vanden Plas, Jaguar XJ6, XJ8, XJ8L, XJ12, XJR Trailer Hitch - Class I - By Curt Manufacturing But that doesn;t mean it's all fine and dandy to do it.
And, I'll need to hack into the lights to get them to run the trailer.
So... thoughts out there in Jag-Land?
Thanks!
Charles
Thanks!
Charles
Hi there. I fitted a tow bar to my 96 XJ6, just to pull a small trailer (4' x 5') and occasionally a 17' boat on its' trailer. I think the general rule of thumb is not to tow anything heavier than the towing vehicle, so I'm well withing these parameters.
I couldn't source an "off the shelf" tow bar for my car here in Ireland, with associated costs being crazy. I finally got one from a supplier in the UK, which worked out at almost half the cost including shipping and came with fitting instructions, wiring, socket etc.
If you're handy with a spanner it's a simple job. I wired straight into the wiring loom in the boot/trunk with no adverse effects at all, although I believe there is a "towing module" of sorts in the boot, but I couldn't find it!
It's a tidy fit, but needed the removal of the rear bumper, which can be problematic in itself, but at least the bumper itself didn't need to be cut in any way. Of course, there is the more expensive option of fitting a retractable tow bar, but I kind of like the extra security of a tow bar in the event someone rear ends me!
Hope this helps.
Hope this helps.
X300 by itself is a heavy car, it is heavier than most Mercedes S-Klasse and equals the heavies S-Klasse built on the scale
The X300 brakes are adequate, without a trailer. In my experience the limiting factor for towing that I ran into first were the brakes. XJ6 should have plenty of power to get your load going, it's being able to stop it that might become problematic.
If you are going to tow with XJ6, make sure that you brakes are 100% and don't exceeded the recommended trailer weight. I'd opt for trailer with brakes regardless of weight. I would also try to avoid congested roads and give myself some extra distance from cars ahead of me.
Rlover
03-30-2016 10:04 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
