Idler Bearing Part Number?
Hey Lads,
So the idler bearing on my XJ6 is making noise. Sounds like sandpaper...lol.
I was looking to replace it but all I can see so far is replacing the entire idle with pulley for 100 or more. It just needs a bearing replaced.
Can the bearing be replaced on the 1996 XJ6 or is it bonded somehow and that's why I can't find just the bearing.
If it can be replaced, does anyone have a PN for it?
Bernie
Bernie
Assuming the a/c belt idler?.
Down here it is the SAME as many Ford, GM, Toyota idlers. The part # down here is EP002, but who knows up there.
The original was a plastic pulley with bonded bearing.
The replacement is steel with replaceable bearing.
Any half decent parts supplier should have a range of pullies to suit, just dont menytion Jaguar. Drop the old on the counter and tell the dude "I want a replacement for that", and let him earn his pay.
Down here $20.
Down here $20.
razorboy (12-26-2015)
Down here $20.
Down here $20.
lol,
I love that!
Make him earn his pay........lol.
Ok, so it figures then that the part is bonded together.
I found one for 35.00 but 15.00 to ship but its OEM so I may just go ahead and grab it.
Received 13,186 Likes
Bernie,
FYI, you can look up the Jaguar part numbers here:
Compressor Belt Tensioner-3.2/4.0 Litre - Parts For XJ Series from (V)720125 to (V)812255 (X300) | Jaguar Heritage Parts UK
And shop for OE Jaguar parts here:
http://www.jaguarmerriamparts.com/pa...&siteid=215718
But probably not as cheap as Grant's suggestion!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Cheers,
Don
Cheers,
Don
Bernie, you can get by for $20, maybe less at your local auto parts store... hang on, let me find a link...
Gates p/n 38006: https://www.jaguarforums.com/forum/x...lt-how-102387/
The following 3 users liked this post by aholbro1:
O-Reily's down the street for 20.00
Heading there now
Thanks a lot for that one.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
The following 2 users liked this post by razorboy:
Don B (12-27-2015),
Grant Francis (12-27-2015)
All done!
Couple of tips.
The square head adjuster can be easily managed buy using the reverse end of a 1/4" extension. The other end goes pretty good into an 8mm socket. So it would be 1/4" ratchet to 8mm socket to reversed 1/4" extension to adjuster.
The 10mm bolt that holds the pulley to the tensioner assembly was tight enogh on my car that I used a 3/8" ratchet with a 10mm socket. It is a normally threaded bolt so expect to put a little force on it.
Clean up the parts and it all goes back together quite quickly and the Gates pulley worked perfectly.
Couple of tips.
Don B (12-27-2015),
FS[Central US]: Factory X Type 16" Anterras wheels....$100
mrplow58
02-02-2016 09:39 AM
