idling issue
So a while back i posted that i had an issue with my idle control.. since then i have replaced the tps, iacv, and the throttle body. the problem persisted, everytime i slowed down the car would stall. so i disconnected the brand new iacv and presto, no more stalling. but i dont want to leave it disconnected as this is not the answer, also sometimes out of no where the idle will drop and the check engine light will come on and rapidly shut off and the idle go back to normal. any ideas?
When was the last time you checked the coils? , a scanner would be very helpful or have them checked at the shop. a cheap and inexpensive way is to wait until tonight remove the coil cover and start your car. should you see any arcing at any of the coils you will know that the coil needs replacing.
joesoap
09-10-2015 01:09 AM
