Idling Misfire - Video
#41
#42
#43
#44
With the new coils one may be arcing to ground on the valve cover . Before the fault accures turn on the AM not FM radio and listen for interference as it does , watch for the voltmeter to go wacko , and see if the RPM needle drops to zero before the engine actually is .
May have a bad alternator suppression module which is actually a capacitor to smooth out the not so smooth DC out of the alternator rectifier . Easy to test .
This may explain why your data points are all over the place if not the correct values . Corrupted data bus
Sounds like it doesn't accure until you put it in drive as this is the shortest injector pulse width and where a unresponsive injector shows up . Try some recommended Techron injector cleaner in the tank
