Idling Misfire - Video
Old 12-11-2017, 03:49 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
My Excel is out on my laptop and will have to review it on another
  #42
Old 12-11-2017, 04:00 PM
still have the old " Made in Japan " labeled coils ?
  #43
Old 12-11-2017, 04:13 PM
The red lines are event markers with respect to the sometimes changing RPMs . Other then that your data points are not stable . The MAF at idle for a 4 litter engine someone mentioned should be around 4 g/s if I remember correctly . Compare the value in Thifty's thread
  #44
Old 12-11-2017, 10:55 PM
With the new coils one may be arcing to ground on the valve cover . Before the fault accures turn on the AM not FM radio and listen for interference as it does , watch for the voltmeter to go wacko , and see if the RPM needle drops to zero before the engine actually is .
May have a bad alternator suppression module which is actually a capacitor to smooth out the not so smooth DC out of the alternator rectifier . Easy to test .
This may explain why your data points are all over the place if not the correct values . Corrupted data bus
Sounds like it doesn't accure until you put it in drive as this is the shortest injector pulse width and where a unresponsive injector shows up . Try some recommended Techron injector cleaner in the tank
