Ignition Switch ??????
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
Hey guys and gals. I found this thingy on ebay and I'm not sure exactly what it does. I'm having trouble with my ignition switch working well. Going to the first position that disengages the steering wheel lock sometimes is very hard to do. I don't know enough about how the switch works to know if replacing this device will fix the problem or not.
Please respong. Need help with this problem.
95 96 97 XJ6 VP Ignition Switch LNA6507BA on column engine start LNA6507AA XJ8 | eBay
Firstly the "ignition switch" as we commonly call it is in fact in 2 sections.
1) The mechanical section (barrel and key in some languages), is responsible for the column LOCK/UNLOCK.
2) The electrical section (the bit you found), is what sends the battery juice to the selected items on demand.
IF, and I say IF again, yours is stiff from the key out position to the column unlock position you have 2 issues that I know of.
1) The column is locked, we know that, and the column/wheels/rack have "loaded" the pin in the mechanical section. Sooooooo by moving the steering wheel "slightly" (as in turning it) whilst rotating the key, releases this Pre-load on the locking pin and its corresponding slot in the shaft, and allows it todis-engage very easily, with NO strain on the workings.
2) The mechanical section (the part the key slides into) needs some lubrication. I ONLY use powdered graphite here, as any other liquid lube will attract dust and screw the workings.
Grant Francis (12-02-2012)
OK, significantly clearer now.
I would try some silicone spray in a p/pack can. It will do NO harm, and will NOT stain anything it may drip on.
Remove the key (yep I know), attach the supplied nozzle, slide it into the lock as far as it go, and spray.
I know these X300 keys do not leave bits behind in the lock as the older style did, but dirt and grime still gets in, and then the lack of lubrication does cause things to bind somewhat over time.
I did the silicone spray thing with the boot lid barrel on my X300,as it had NEVER been used, and too late when the electrics dont play games no more, and it took some serious spraying, and careful working of the key to get it as it should be.
From the sounds of it this silicone spray task certainly cannot do any more harm.
Failing that a decent, reputable locksmith should be able to revitalise the barrel.
EZDriver (12-02-2012)
I found that inserting a very small screwdriver into the tip of the barrel released the little sliding gate mechanism, thus freeing the tube, which slid out easily. Just a little warning!
EZDriver (12-03-2012)
Just a word of caution. I recently used a lubricant on my ignition barrel in the manner described above. Just afterI inserted the thin tube into the barrel to spray the lubricant in, it gave a "click" sound, as though locking and I then discovered that the thin tube wouldn't release! No matter how hard I pulled on it. I was dubious about pulling too hard, as if it broke, leaving a piece inside the barrel would have been a minor disaster.
![Icon Couch](https://www.jaguarforums.com/forum/images/smilies/icon_couch.gif)
bliving7 (06-19-2017)
Scotlad (05-09-2018)
rentzoo
11-10-2015 04:56 PM
Johnken
09-22-2015 03:53 PM
1964Daimler
09-09-2015 11:28 AM
