Inertia switch location
Not sure on the amount of relays on a 95 fuel circuit, but I think the inertia switch is on the right by or behind the side kick panel. I’m assuming you have no fuel by your questions.
Did you put direct power to pump through relay plug to see if pump kicks on? Pump will work regardless of switch and other potential relays, but if switch tripped I believe you still wouldn’t have spark. Good luck.
Neil
Neil
Thanks for the reply Neil. Yes that's where the inertia switch is located on my 95. The no start problem was the car was not getting gas, fuel pump wasn't turning on. After the usual relay, inertia testing I figured the 4 year old Walbro fuel pump was shot. The fuel pump problem was not the pump but the black "pigtail" wire on the pump's plug was off, WHY????? Soldered the wire back to the connector, preliminary test "turning key on/off" show pump is working.
The following 2 users liked this post by 44lawrence:
Cafcpete (04-22-2020),
nunger1330 (04-22-2020)
geneo
05-12-2018 03:47 PM
