Inertia switch question?
I was driving this evening going around 20mph. Then I hit a big pot hole on the passenger side, right after that the car beeped and turned off. No warning lights came on. Right after that the car wouldn't start I thought I did some great damage. No warning lights came on just like radio and interior dome light. So I knew it wasn't the battery. I searched a little and read about the inertia switch, I eventually found it pressed it. Then the car started! So my question is could the inertia switch make it so the car wouldn't even crank? I thought I had a loose ground.
I am assuming an X300 ?????.
Not sure what it kills on mine, never tried it.
On the XJ-S it kills the fuel pump circuit. The S2 XJ12 does the same, and also the starter circuit, not sure if that is by design or just old age.
I reckon you got other gremlins, but if its running and doing what it should, dont mess with it.
Bugga, I need a drink, so do you.
The inertia switch has NOTHING to do with headlights, full stop.
I would start by checking some earth wires, and the main battery cable connector at the +ve battery terminal.
Something else is loose, and caused those outages.
Reading my handbook and other stuff I got, the inertia switch is "fuel circuit safety OFF", which was my thoughts in the first place.
Received 2,193 Likes
1964Daimler
09-09-2015 11:28 AM
