Install X308 XJR front sway bar on an X300
Old 04-15-2018, 09:04 PM
Ric in RVA's Avatar
Default Install X308 XJR front sway bar on an X300
I recently acquired a front sway bar from an X308 XJR.
I also have the XJR rear sway bar.
The X308 bar is shaped different but I believe it only to be shaped so that the different links fit correctly.
Does anyone know if I can bolt of a X308 to an X300 using X308 links?
I can't find anything different about the mounting brackets...but not certain.
Thanks for any advice!!
Old 04-15-2018, 09:14 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
The sway bar poly bushings are larger but not a big deal . Andy makes vertical links on the outer points that somehow without looking back at the geometry improve cornering .
https://www.jaguarforums.com/forum/x...rience-130749/
XJRengineer (04-24-2018)
Old 04-15-2018, 09:26 PM
Ric in RVA's Avatar
I have a message into Andy about those links.
Great I will plan on swapping the bars after I get some links.
Old 04-15-2018, 09:38 PM
Received 12,949 Likes on 6,469 Posts
In the thread Lady P linked to, Andy (XJRengineer) says the X308 sway bars use drop links with metric studs, but the XJ40/X300 use drop links with Imperial studs. You might have to somehow adapt the X300 drop links to the holes in the X308 bar, but I don't know if that might mean drilling a larger hole in the bar or if a spacer of some sort might be required to prevent the stud from rattling around in the hole. Andy may know.
Cheers,
Don
Lady Penelope (04-15-2018)
Old 04-16-2018, 06:00 AM
Ric in RVA's Avatar
Good to know. Got a lathe in the shop so not a huge issue. Very handy tool.
al_roethlisberger
06-17-2024 08:56 AM
brgjag
10-23-2015 07:31 AM
XJ8JR
10-21-2015 12:04 PM
jimlombardi
11-03-2014 07:35 PM
04xtype04
05-04-2014 09:27 PM
Quick Reply: Install X308 XJR front sway bar on an X300
