Instructions for opening X300 1995 XJR remote fob
Old 12-13-2011 | 02:31 PM
WaterLew's Avatar
Question Instructions for opening X300 1995 XJR remote fob
Can someone direct me to, or provide instructions for opening the X300 1995 XJR remote fob so I can see the FCC transmitter ID?
I need to examine the last 3 numbers of the FCC transmitter ID to determine the frequency of the fob. I have one fob that works fine and a another one I bought on eBay that doesn't. I want to rule out frequency mis-match before I go any further.
I just don't want to do anything wrong to damage the fob while opening it since these things are so rare (and expensive).
Thanks!!
Old 12-13-2011 | 04:37 PM
5tevie's Avatar
If it is the same as the fob for a 1995 XJ6 with the 2 buttons it is just a case of using a sharp tool to pry open one end of the brass ring and then pulling the ring away from the fob. Then use a knife to pry apart the 2 halves.
That's how I did mine.
Old 04-08-2018 | 08:28 PM
thisismurph's Avatar
is there a battery in there ??
Old 04-08-2018 | 09:31 PM
Lady Penelope's Avatar
The freq . is on the the outside of the battery cover itself and it takes 2 X 3 volt batteries . You need good light or a magnify glass in the dollar isle at the hardware store or you can test drive there more expensive magnifying glass product offerings . Be careful of the cheap dollar store batteries .
Don't pry on the battery cover as the removal instructions are in TSB 18- 9 below and replacement microswitches and rubber button covers are avail on Ebay , cheap and free shipping . There are a couple of TSBs on the FOB in this source starting with 18 - 4 :
http://www.jagrepair.com/X300TSB.htm
1995 is most likely a 315 hz and 433 hz came in later on the X300
Just picked up a 315 from a small salvage yard for $ 20 and will see if it works later .
aholbro1
08-05-2021 06:02 AM
mbergen
10-23-2019 11:26 PM
dsnyder586
04-04-2019 03:38 PM
AL NZ
09-04-2015 09:39 PM
Quick Reply: Instructions for opening X300 1995 XJR remote fob
