Instrument Cluster Light not T4
Old 04-10-2018, 08:24 PM
cdma's Avatar
Default Instrument Cluster Light not T4
SO I am replacing the bulbs in my cluster. A few threads he talk about T3 and T4. I used those in my Clock and temp display but they are too small to fit in the Instrument cluster. I also saw 8.7 was also used. Any help out there.
Old 04-10-2018, 11:34 PM
Lady Penelope's Avatar
Received 1,387 Likes on 1,090 Posts
Without seeing it they may be grain of rice or grain of wheat bulbs in the below pic :
Dimentions are on this link : They come in 5 volts so be sure you get 12 volt when ordering . Penty on Ebay
http://www.elfminiatures.co.uk/12v+B...0RkalZIWnZKSGM
Old 04-11-2018, 04:38 AM
cdma's Avatar
The cluster that pulled off the parts car that I bought has twist on for all the lights that is why I am confused. Am I missing something. Trying to do an LED upgrade
Old 04-11-2018, 09:11 AM
cdma's Avatar
Went ahead and ordered D8.3 LED lights. We will see if that works
Old 04-11-2018, 07:40 PM
devonia's Avatar
Hello
On my 1997 XJ6 there were originally two versions of bulbs:
> 24 off JLM28 (orange); and
> 8 off JLM29 (white).
The JLM29 has now been replaced by the JLM28 (i.e. 32 orange based bulbs).
I have replaced these using the Ring autobulb number: R509TWGY
These are 12V / 1.2W and sold in packs of 10.
I suggest you DO NOT use a incandescent bulb in your clock. They emit too much heat and will melt the connection of the ribbon cable to the board. AKSpeedo (akspeedo.com) offers replacement LEDs.
Lady Penelope (04-12-2018)
Old 04-12-2018, 04:22 AM
cdma's Avatar
Thanks for the response but I am looking for the LED replacement
Old 04-12-2018, 11:28 AM
devonia's Avatar
Hello
LEDs are definitely the way to go, if possible.
Please post if they fit and are dimmable.
Thanks.
Regards
Richard
Old 04-12-2018, 05:52 PM
rod_f's Avatar
B8.7D from memory for the 8 illumination ones (the white ones in the picture), I got some from here in June 2016 and they still all work
And yes, the dimming works.
https://www.superbrightleds.com/more.../attributes/14
Old 04-15-2018, 04:52 AM
cdma's Avatar
Received my lights and they do not fit so sending them back. I sent them a message that they don't and told them that I would send them a light so they can figure out a replacement. Waiting to here back from them
Old 04-17-2018, 09:47 AM
cdma's Avatar
So I sent superbrightleds pictures and dimensions of the bulb for the cluster. They are telling me that they are this one https://www.superbrightleds.com/more.../attributes/27
I have to send all the other bulbs back and reorder when they get them. I will follow up with if this is the correct bulb or not.
Old 04-17-2018, 12:49 PM
Vee's Avatar
Vee
Vee is online now
Received 1,575 Likes on 1,223 Posts
Please let me know...I ordered B8.3D in the past and it did not fit. The bulb holder and the hole were the exact same size, so I could not get it to fit.
Old 04-25-2018, 10:08 PM
cdma's Avatar
It is the B8.7D. I tried to go through the customer service sent them pictures and measurements and everything they needed to send me the correct one and did not work so I ordered every possible light that could fit and the B8.7D was the only one that worked. What is nice is if I ever can't figure another one out I have plenty to try.
car5car
05-05-2017 09:31 AM
xjrjag
09-24-2015 10:08 PM
dneu
08-12-2015 11:17 AM
SteveSheldon
02-17-2013 09:04 AM
newboy
11-23-2010 05:04 PM
Quick Reply: Instrument Cluster Light not T4
