Interchangeable Wheel Hubs from x308 to x300 XJR
I just bought a used '96 XJR6. She drives and everything seems to work except...... The previous owner changed the rims for some gross 20' monsters and he had to change the hubs to accommodate those monstrosities. So I need hubs for all four corners. I also have a 1999 XJR that wont drive. I am wondering if I can interchange the X308 hubs to the x300. The local Jag shop near me quoted $2800 to do the job including parts and labour. The price included new wheel bearings, used hubs and something else that I forgot. He said might as well change the bearings as the hubs were already going to get changed.
Alternatively, can anyone suggest a place where I can get a new or used set of hubs? Ideally with newish bearings.
Thank you all!!!!!
Thank you all!!!!!
rears yes front no, go to the junkyard and find an x300. on the 308 just pull the whole rear hub carrier with half shaft, only difference is holes for the abs sensor bolt, just glue the x300 sensor on.
$2800 is robbery but that’s to be expected from a jag specialist
