Jack Daniels Wiper Fluid Container?
Old 06-30-2010 | 12:43 AM
bgy08's Avatar
Default Jack Daniels Wiper Fluid Container?
A while back I was in a wreck that busted my wiper fluid housing, and messed up the fluid motor and sensors. I was wondering if its possible to mount a big glass liquor bottle (saw it on a hot rod, thought it was a cool idea), and make the whole thing work again. Any ideas??
Old 06-30-2010 | 04:20 AM
Anything is possible, as long as you enjoy the liiquor PRIOR to installation.
The earlier XJ cars had a long thin washer bottle, with the pump mounted out the front with a hose supplying the pump.
A glass container rmay NOT meet crash testing safety issues, but who worries about that when the front gets biffed. Plenty of other glass flying aroung anyway.
Old 06-30-2010 | 07:31 AM
Cadillac's Avatar
That reminds me of pouring a glass of milk into the kettle and boil it
Ha ha
Old 06-30-2010 | 10:38 AM
TopHatChef's Avatar
It would be pretty difficult because I believe the fluid level sensor is fitted at the bottom of the reservoir, so you may crack the bottle trying to fit that. Also, the bottle would be a bit small to hold the fluid, but you could just fill it up frequently.
Old 06-30-2010 | 11:16 AM
Drew's Avatar
If you don't care about the sensor level you can jumper the plug and that will turn off the dash ligh.
Old 07-04-2010 | 05:08 PM
steven300's Avatar
Default washer bottle
a very close fit ,is one out of a 93 to97 dodge intrepid.the neck is about 3" too short,but if you've got a good eye you won't spill much.[sorry purrests]..steven
Old 08-05-2010 | 01:50 AM
bgy08's Avatar
Drew, how can I jumper the plug? What does this mean?
Old 08-05-2010 | 10:07 AM
Drew's Avatar
Connect the the two wires together in the wire harness. Add a jumper wire to connect the leads. The washer fluid level is just a switch that turns the eletrical circuit on and off.
Old 12-09-2012 | 07:54 AM
jagiam's Avatar
hi can anyone tell me where the low washer fluid sensor is on a 2000 xjr.thanks.
Ferdie
11-26-2018 06:42 AM
Dave1109971
12-15-2015 07:16 PM
LnrB
10-13-2015 01:45 AM
Jaguar Forums Editor
Jaguar Press release
09-28-2015 06:18 PM
