Jag Electrics
Jag Electrics
Alright, so I was driving my 1997 VDP a few days ago when my car randomly shuts off, no sputter or anything. So I assumed that it might have stalled or whatever, until the next day when I noticed the guage cluster dancing and putting on a light show, each time ending with a different warning light. The car starts and operates fine until it reaches running temp. then it shuts off. HELP!
Received 10,975 Likes
Mine has done the same thing.......gauges go crazy and tokyo-at-night light show with the warning lights. No stalling, though.
In my case...two separate instances....a faulty coil was to blame.
Following advice from others here I was able to isolate the offending coil by removing the coil cover and running the engine in a dark garage. If you see a faint flashing in the translucent potting material of the coil, that's the problem coil.
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
