Juddering under load (moved to the correct forum )
Hi guys, hope someone can help!
I’ve recently just purchased a 1997 XJ8 3.2 with LPG conversion.
It developed a water leak from one of the two hoses that run under the inlet manifold, so I removed this and replaced the two hoses, leak cured.
Now however I am experiencing juddering and loss of power, most noticeable when on the motorway, and asking for power in the 2k ish rev range. If I drop down the gears the juddering goes, but seems lacking in power somehow.
It does this both with LPG and Petrol systems. It also did the BEFORE the hose change for a couple of days but seemed to cure itself.
Any ideas would be very welcome!!
Thanks!!
Steve.
Thanks!!
Steve.
You might have better luck in the correct forum. This is for 2004 and newer. Good luck.
Jaguar XJ8 & Jaguar XJR - Jaguar Forums - Jaguar Enthusiasts Forum
MC36
US Lower Atlantic
09-01-2015 07:34 PM
