Jurid Coupling Renewal
I observed a need for this procedure during a recent preventative maintenance action:
https://www.jaguarforums.com/forum/x...6/#post2117308
Yes! I should've renewed the pinion seal while I was at it...but I needed a quick turn-around to make shop space for an incoming project. I topped up the diff with fluid and will save that task for a later date.
Fortunately, Motorcarman had replacement parts available, and was forthcoming with sage advice!!!
"Bob, I read an involved and confusing thread about propshaft alignment on the forum...do I need to be bothered about that?"
(puzzled look) "I don't see why...just mark the position of the center bearing support - well, you can see where the washers were - and put it back where it was, I've never had a problem."
"Anything else?"
"Remove the handbrake compensator first and get it out of the way. Then remove the bolts from the center bearing support. I always remove the jurid bolts from the differential flange first, then from the driveshaft. Stick a big pry-bar in there between the jurid and differential flange and pry it forward until you have space to get the jurid out."
So here you go:
There is no jurid renewal procedure. The closest I found was the differential pinion seal renewal. Jaguar say, "Don't you dare loosen that jurid from the propshaft flange!!!"
Not wanting to get bogged down with handbrake adjustments later, I started counting threads. However, I soon ran out of fingers and so grabbed a handfull of washers and a couple of M8 nuts to fix the distance I'd need to spin the handbrake compensator fixing nut back on upon re-assembly.
Handy way to remember how many washers I used. I inexplicably have a small box of M8 studs of the proper thread pitch.
I'm over-run with various-sized empty plastic edifices. I call them "suitable containers" and can generally find a size suitable to house my take-off parts. Keeps the shop-spiders and toads from scurrying off with the small bits
Although I initially "broke torque" on all fixings using hand-tools, prior to applying pneumatic assist, I had one center bearing fixing that only came out about 1/16" before the weld-nut or whatever back-up thread it screws into began spinning.
Fortunately, both fixings came out on the left side!
The pilot on the prop-shaft inserts into the differential flange. You need to pry it back (forward) far enough to disengage to free the jurid
It was well-knackered!!!
"Anything else?"
So here you go:
- Raise and support rear of vehicle, leaving gearbox in neutral and handbrake disengaged
- Mark distance between handbrake compensator fixing nut and end of rod
- Remove handbrake compensator (13 mm socket)
- Mark the position of the center bearing support and its fixings
- Remove 4 center bearing support fixings (10 mm socket and wobble-extension)
- Remove 3 jurid-to-differential flange fixings (19 mm socket and 19mm back-up spanner)
- Remove 3 jurid-to-propshaft flange fixings (19 mm socket and 19mm back-up spanner)
- Insert pry-bar between jurid and differential flange and pry rear propshaft forward to disengage pilot from differential flange
- Remove and renew jurid coupling (SGF 249937)
- Put it all back by following steps in reverse order
- Center bearing support fixings torque spec - 19-27 nm
- Jurid-to-differential flange torque spec - 71-83 nm
- Jurid-to-propshaft flange torque spec - none given; remember? Jaguar say, "DON'T DO IT!!!" but I extrapolated and used 71-83 nm
The following 9 users liked this post by aholbro1:
AnttiM (06-04-2020),
b1mcp (09-02-2019),
Cafcpete (09-01-2019),
Don B (05-31-2020),
Lady Penelope (09-01-2019),
and 4 others liked this post.
times2fxp
11-13-2015 07:53 AM
