Key Fob.
Key Fob.
I have three keys with my Sovereign. Two are black and have the fobs with them, the third is a green key without the fob. Unfortunately, one of the fobs has refused to react to any button pressing. I have changed the batteries for new, but no luck. I would like to get inside said fob to attempt to diagnose any fault, but can't see how to. Any ideas? Secondly, I do have a fob from another manufacturer, and I would like to programme it for use with the Jaguar. Does anyone have a method of so programming? Thank in anticipation. AlecG.
The FOBs come in 2 Freq as 315 and later 433 hz
You can tell by the rear window as the antenna shape is Diff
There is a cavoite in that the wrong antenna is installed at the factory not matching the FOB / Security Lock Control Module , with compromised performance
There are cheap parts specific to the X300 FOB ( and used on Volvo or could be Saab , hint )
fits Jaguar remote key fob X300 XJ6 XJ12 - 2 Silicone Repair key Buttons (1SET) | eBay
These switches off the top of my head don't look right , will have to look in my toolbox later, but at least they are from England
4 Micro Switches for Jaguar Remote Key Fob | eBay
There are several TSBs and maybe how to open , see section 18
JagRepair.com - Jaguar Repair Information Resource
Cheap batteries no good as well as the batteries can be upside down
You can take a common pencil eraser and clean the battery contacts
The green key is probably a different cut / shape for the valet key
Cafcpete (08-16-2024)
[QUOTE=Parker 7;2776487]The FOBs come in 2 Freq as 315 and later 433 hz
[/QUOTEI have the lower antenna, so it is 433Mhz.]
The small FOB circuit board does come out maybe clipped as I need to take off for hours and I had my FOB boards out before , getting my memory going
To know the antenna is matched to the SLCM the freq is on the SLCM but a job to get to under the fuel fill well in the trunk
The SLCM is installed at an angle , if removing the connectors , remove the battery positive cable
There is a SLCM hard reset but before doing that you have a precaution for your British model
There is history of water getting into the SLCM connectors and this locks up the SLCM logic steps to not get to zero state
I have now obtained another key fob of the correct frequency! Now I need to programme it to the car. I have found some confusing directions on YouTube. Does anyone have a written “How to do it” or service recommendation?
