Key Locked in Trunk - It's Not The Valet Switch - Help Me!!
This really sucks:I locked my only regular key in the trunk while I was replacing the trunk microswitch. The new microswitch was in, but the dashboard release latch and electronic trunk badge release still didn't work. So I closed the trunk once more to try it again, and as soon as it shut closed, I thought, "Damn". I have a valet key, but that doesn't open the trunk. I even tried disconnecting the wiring to the valet switch to see if that would do anything. Also, when I bought it used, it didn't have a key fob, just a black key and a green key. So I can open the doors and drive the car, but the trunk won't budge. I called my roadside assistance, but they said that they didn't have the equipment to make a hi-security key, and they didn't want to drill or break the lock for liability reasons. So what's the best way to get that thing open?
Thanks,
David
Thanks,
David
RE: Key Locked in Trunk - It's Not The Valet Switch - Help Me!!
The only difference between the green valet key and the black master key is the very end …the end of the master is smaller …it has a small ring cut around it …if you know some body with a jag take a look at there keys it is easy to see ..you can grind or file the ring very easy takes less than five minutes ….or get the dealer to cut you a new master from the valet key
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
