Key Remote Fob for XJ6 XJR XJ12 X300
Not sure if this info has been posted before, but I could find nothing here about it.
Anyway….I could not bring myself to purchase a replacement remote for my XJ6 when I found info that the Saab 900 remote will work just like Jaguar’s.
Wasn’t sure if it would work, so found one on eBay for $20 (SAAB LTQFM433 Factory OEM KEY FOB) and took a chance, and walla! Received today and just finished programming it to the car and it works just like my old one.
Hope this helps someone else out there, I just purchased two more from the same seller!
![](https://www.jaguarforums.com/forum/attachments/xj-xj6-xjr6-x300-26/74218-key-remote-fob-xj6-xjr-xj12-x300-remote.jpg?dateline=1393541758)
The following 6 users liked this post by knealy2:
Chattanooga_XJR (06-10-2014),
KWalton (11-20-2016),
newheart8 (07-22-2014),
someguywithajag (08-15-2017),
tompullizzi (02-19-2023),
and 1 others liked this post.
My experience was that neither of my 2 original key fobs had batteries in them when I bought the car. When I fitted new batteries the small indicator lights illuminated on one of them, although very dimly. The other fob showed no signs of life at all. I then spent a lot of frustrating time trying unsuccessfully to re-program the "illuminating" one. In the end I decided to open them up and check the tiny button contact points, which strangely enough appeared less worn in the non-working fob. I removed the points from that fob and soldered them into the "illuminating" fob (you need good eyesight, a steady hand and a fine tip soldering tool for this job! - you can also buy replacement points on eBay). As I was doing this job the car was close by, and the moment I refitted the batteries, presto! the door locks responded. It has worked perfectly ever since. I'm not sure why the good points wouldn't respond in their original fob, unless another part of its circuitry was faulty.
The real point here is that despite advice given in the handbook, disconnecting the batteries for a lengthy period does not necessarily cause the fob to lose program. Mine were non-functional for just over 2 years in my ownership and I have no idea how long they had been in that state prior. Despite this, re-programming was totally unnecessary.
The following 2 users liked this post by BlackX300VDP:
mgb4tim (06-11-2014),
The following 4 users liked this post by motorcarman:
The TSB that I uploaded is for the NORTH AMERICAN MARKET!!!!!!!!!!!
I got the TSB from Jaguar when I worked at the dealer.
THERE ARE 2 FREQUENCIES!!!!!!!!!!!!!!!!!!!
Jag dealer in AZ. is WRONG.
The sure way to know what frequency you have is to remove the SLCM and read what is on it. People can change modules, especially on cars this old.
bob gauff.
The following 2 users liked this post by motorcarman:
cool (06-16-2014),
I just bought a used 315MHZ for 1997 xj6 and it did not work. The reason I asked the question earlier to Knealy 2 with his 1996 so I potentially buy the cheaper Saab fob. There are no American version or England version. Short wheel base with VIN number higher than VIN 759614 uses 433Mhz. For sure all shortwheel base 1997 and maybe some 1996 use 433Mhz
From all this I've gleaned that my early '95 X300 has the 315Mhz system, right? I need to get a key fob.
The following 2 users liked this post by RJ237:
ronlaw61 (07-20-2014),
I just went outside just to put my xjr in learning mode. At first it wouldn't work but are you making sure all doors/trunk are unlocked (turning key twice to unlock)? After I unlocked all doors/trunk I was able to put it into learning mode. That's as far as I got since I haven't ordered the key fob
