Key Remote Fob for XJ6 XJR XJ12 X300
1. Open trunk
2. Open drivers door
3. Turn ignition on but don't start the car
4. Rock valet switch 5 times
After those steps, you should hear the chirp and also headlights flash
Didn't work. The thing is, I am still sorting through this car. The check engine light is on, and I took it to a nearby auto parts store, and they say that both anti-knock sensors are showing as bad. Don't know if I should trust a cheap scan tool though. And certainly don't know if that would cause the cruise not to work either. Ugh, what makes us like these Jags so much?
I stand corrected. I opened the truck, left the drivers door open, turned on the switch without starting, and with three quick presses of the valet switch, the car chirps. But the remote I bought for a Saab won't cause the car to chirp again, no matter how long I hold it. Any tips appreciated. We knock these things out one at a time, lol
One of the first ten posts in this thread there is a link to a PDF that show the two different ways you can tell which frequency your car uses. I can't pull it up right now since I'm on my mobile Ipad app and can't view PDF files.
tompullizzi (02-19-2023)
That seems to be where your problem is then. Mismatched frequencies between your car and the key fob. Hopefully the seller would be able to help you out.
I just my Saab fob and it did not worked for 1997 XJ6. The seller advertised as a 433Mhz but i checked inside the battery cover and it was a 315Mhz. Three times is the charm. I will buy another Saab fob and will make sure the seller check inside the battery cover. I refuse to pay $100.00 plus US dollars for a used Jaguar key fob.
#30
Received 10,936 Likes
#31
Doug (06-26-2014)
#32
#33
My Saab LTQFM433 came in the mail today and is 315 mhz and will not work in my 1997. So I emailed the seller to see if he has a 433 mhz. I paid $16.88 for the 315 mhz FOB. So far, I have not found the Saab FOB 433 mhz FOB like the one in the OPs picture. We need the model number of the Saab 433 mhz key FOB that will work in a 1997 Jag. Anyone???
#34
#35
I guess this is the only one that will work on a 1997 XJ6? They must know it and that is the reason for the high price.
Keyless Remote Key Fob Entry K85JTX433 Clicker Jaguar XJ6 XJ12 XJ Control | eBay
#36
I talked with the seller of the Saab remote I bought. They suggest I send it back for a full refund. It is a 315 MHz. The XJR (x300) cars switched frequencies along the way somewhere in 96. My car is a 97. It is the 433 MHz. The seller took all of the Saab remotes he had apart while we were on the phone, and said all of them stated 315 MHz, although the part number leads you to believe it is 433MHz.....sigh...the search continues...
#37
I have one getting delivered on Monday but now I'm afraid it won't work...
or a link to the auction?
#38
The seller is "keylessentryremote" on eBay. I feel that we are chasing a dead end on the 433 MHz cars. I talked with good friend that owns a locksmith shop. He felt that the only remote that would work is the 97 specific remote. 98 went to trunk release button, and a panic button. Most likely different.
#39
Good News. I took a chance and purchased one of the following "Code Learning" 433mhz Fobs and it worked like a charm. But this is ONLY for those with at least one currently working Fob. Total cost $13 shipped from UK to US.
Universal Garage Door Cloning Remote Control Key Fob 433MHz Gate Copy Code New | eBay
annamiata (06-29-2014)
#40
