Key Remote Fob for XJ6 XJR XJ12 X300
Old 02-16-2020, 06:02 PM
gibbon's Avatar
Default SAAB LTQFM433 remote for 95 XJ6 VDP
I just received 2 remotes from Ebay and they both programed to my 95 VDP which is MHz 315.
Do not get confused by the Saab part number ending in 433, it is not the frequency. These are 315MHz.
I think the seller still has a pair for sale at the same price. Search LTQFM433.
The following 3 users liked this post by gibbon:
1 of 19 (02-17-2020), Cafcpete (02-17-2020), SleekJag12 (02-17-2020)
  #102
Old 03-10-2020, 12:37 PM
Jeremy Faris's Avatar
I bought a set of these SAAB keyfobs from the same seller, thank you. I can confirm they work as well.
  #103
Old 07-18-2020, 07:32 PM
Jagicon's Avatar
Hello ! Glad to find some info on the FOBS.. I have 2 fobs, non-working, for my 97 xj6L... I was told to put new batteries in them and reprogram them. Would you or anyone out there have the correct reprogramming directions for this? I think I remember seeing them online once before. Everyone here seems to say "reprogram" like it is EZ but if I remember it requires a lot of steps... any help would be most appreciated... thank you!
  #104
Old 07-18-2020, 07:55 PM
Received 8,183 Likes on 4,936 Posts
TSBs are your friend.
File Type: pdf
Cafcpete (07-19-2020)
  #105
Old 07-20-2020, 09:58 AM
Jagicon's Avatar
Smile
Hello! Thank you so much for giving us all the pdf instructions on programming the FOB!
  #106
Old 08-22-2020, 10:52 PM
Jane Cavanagh's Avatar
Default Thank you
I am really hoping this can help me with my 97 XJ6 too.
Can I ask how you programmed the fob? I have just read another post from another owner who listed the following steps. Are these what you used?
open the driver side door
pulling highbeam lever and holding
put the key and move to i position
and release the highbeam lever
and quick flash highbeam 4 times
and you can hear horn once
after sound press lock button each key fob which you want to setting
(also you have to press lock button which in key box)
and remove the main key from key box
you can hear the horn twice.
Finish self setting your jag key fob.
  #107
Old 08-23-2020, 07:15 AM
Default Programming
No. I doubt that I’ll work. A few posts up in this thread a member posted the .pdf to Jaguar service procedure. I even remarked on thanking that person for posting. The Saab key fobs the buttons are backwards though....no biggie. I even took one Of mine apart and moved the rubber buttons.
also when you program, the order in which you do so corresponds with driver numbers? Like the first fob is driver 1 I think? For the seat and column memory system. So if it’s all working and you unlock with the fob that corresponds to your saved memory numbert....it should start moving or already be done when you get to the car. If another driver had moved things.
  #108
Old 08-24-2020, 12:26 PM
Jagicon's Avatar
Hi Jayne, I was never able to reprogram my fobs... I plan to do this very soon and have found a local jaguar service person to help me with this. I will update when I know more.. good luck,, Dee
  #109
Old 08-24-2020, 04:12 PM
Thank you. And, good luck.
  #110
Old 09-15-2020, 12:38 PM
Jagicon's Avatar
Hi Motorcarman! This manual for reprogramming the FOBs .. it says for a 1995-96 model. Will this work on the 97 xj6L as well? thank you so much! Jagicon
  #111
Old 09-15-2020, 02:46 PM
The procedure is the same for ALL X300 sedans.
Jagicon (09-15-2020)
dsnyder586
04-04-2019 02:38 PM
Rick Michael
09-06-2015 06:53 PM
AL NZ
09-04-2015 08:39 PM
My Pham
09-04-2015 03:37 PM
Quick Reply: Key Remote Fob for XJ6 XJR XJ12 X300
