Keyless Entry Fix
Keyless Entry Fix
I've been driving the X-300 since 95 and have had my share of trouble with the keyless remote. Recently I was able to fix two remotes. On both remotes the studs from the two battery contacts where thay attach to the circuit board had cold solder joints. I removed the old solder with some copper braid that is for solder removal. Fresh solder and all was well. Another problem was that one of the micro-switches was stuck. I put some WE-40 (sparingly) on the switch and it freed up after about thirty minutes. Circuit board are not as fragile as I've always thought.
Hope this helps someone out there.
Bill Livingston
Bill Livingston
