Lack of power and MPG @ 13-14 suddenly help
Old 05-14-2016, 09:16 AM
aacpa15215's Avatar
Is it possible carbon build up in exhaust manifold?
  #62
Old 05-14-2016, 01:52 PM
Jagboi64's Avatar
Received 3,173 Likes on 2,095 Posts
Originally Posted by Padre
So maybe just maybe, for a Jaguar, 70% may be WOT. But I'll be happy to be corrected if wrong.
I can get mine to 98% on an XJR.
  #63
Old 05-14-2016, 01:57 PM
Jagboi64's Avatar
Thinking further, is the mileage what the computer is recording, or what you are measuring at the pump when you fill up? Just wondering with all the work you have done to the fuel system if you have a leak somewhere? Possibly in-tank, if the small piece of hose has come off the pump pickup? There was photos of that on here a few months ago.
The low performance is one symptom of either reduced fuel flow or low fuel pressure, but you should not get poor mileage to go along with that. An external leak causing low fuel pressure on the other hand would cause that.
  #64
Old 05-14-2016, 02:05 PM
SD96XJ6L's Avatar
OK here are some results from the Torque App
My LTFT are at 7 now, the LTFT same as before.
The MAF reads between 1 and 13 cfm roughly
I did see this failure on a test but I can't decode what this really means. A faulty 02 sensor? If so which one? Bank 1 Sensor 2?
  #65
Old 05-16-2016, 11:39 AM
knightofgold's Avatar
Is that your LTFT at idle? How does the STFT & LTFT look when driving around? Is it the same on both banks?
I haven't used the torque app before, so I am not too familiar with how it displays data. But you should be able to get readings for fuel trims on both bank 1 and bank 2 and voltage for all 4 O2 sensors. I have found the cheapy $100 harbor freight OBD scanner will give all this info in live mode.
littlelic69 (05-17-2016)
  #66
Old 05-17-2016, 05:40 PM
SD96XJ6L's Avatar
More screenshots from Torque
  #67
Old 05-18-2016, 09:51 AM
Jagboi64's Avatar
Was this at idle? If so, those numbers look suspect. Idle throttle position should be around 12%. Not sure what the 2 AFR gauges show, but one is indicating very lean, the other very rich. The MAF gauge is also showing a volume, not mass. It should be indicating in kg/s not CFM.
  #68
Old 05-18-2016, 11:42 AM
SD96XJ6L's Avatar
It was at 40% throttle...
  #69
Old 05-18-2016, 03:42 PM
Jagboi64's Avatar
in a poor way I guess I'm asking if that was reasonable under the test conditions at the time. If it was at idle, yet showing 40% throttle, which should be incorrect; then we have to dig further.
  #70
Old 05-19-2016, 11:36 AM
SD96XJ6L's Avatar
It's not at idle. It's at 40% throttle when I took that screenshiot. I hate this car!!!!
  #71
Old 05-20-2016, 08:52 AM
sparkenzap's Avatar
Received 1,064 Likes on 867 Posts
Since I clearly don't care if you call me a ******** again, I will re- suggest you take the multiple suggestions that you look into the possibility of a bad MAF sensor!
  #72
Old 05-22-2016, 05:56 PM
SD96XJ6L's Avatar
I appreciate your input man. I just thought you were jumping down my throat a bit last time. Water under the bridge. Your insight and opinion are highly respected and appreciated.
Are the aftermarket rebuilt MAFsensors any good? I don't want another used one that can end up in a similar situation...
What about this one?
1997 Jaguar XJ6 Mass Air Flow Meter All Models 49-00298 R
  #73
Old 05-25-2016, 08:13 PM
sparkenzap's Avatar
Wow! That is a lot of money. Do you know anyone you could borrow one from? How did "your guy" claim he tested yours? I have one here, but I ma not sure it is any good, either.
I read that they had become less available, but I had no idea how much they cost these days!
  #74
Old 05-25-2016, 11:13 PM
Jagboi64's Avatar
I see them on Ebay UK fairly cheaply, under $100 anyway. Lots around £30.00 plus postage
  #75
Old 05-31-2016, 02:53 PM
SD96XJ6L's Avatar
I purchased a new to me, used, MAF from a British parts recycler in Ranchco Cordova, CA. Cleaned thoroughly with MAF cleaner AND....No difference...ARGH
  #76
Old 06-02-2016, 12:58 PM
SD96XJ6L's Avatar
I believe it could be the timing advance is an issue. At full throttle I'm getting 19 degrees max. What could cause this?
  #77
Old 06-02-2016, 01:47 PM
EZDriver's Avatar
Timing has seemed to me to be the problem for some time. I don't know if the crank damper could cause this or not. Easy to check the damper. Put white marks on all three flanges in line. After the car runs for a while they may move indicating a bad damper. Just another idea.
  #78
Old 06-02-2016, 02:28 PM
SD96XJ6L's Avatar
While at my mechanic today, he mentioned that. I will do that.
The fuel trims check out ok on the highway, so perhaps that isn't the underlying issue. I'm so frustrated with this.
  #79
Old 06-02-2016, 03:25 PM
EZDriver's Avatar
Most mechanics that I know don't know how to check the crankshaft damper. There are three ranges or rings on the damper. Put a white paint dot on each flange. Drive it. They must stay lined up after you stop. May take some driving. If they don't that could be the problem.
  #80
Old 06-03-2016, 12:02 AM
Jagboi64's Avatar
Timing will be retarded under full throttle. You'll see maximum advance under light throttle highway cruise conditions.
Quick Reply: Lack of power and MPG @ 13-14 suddenly help
