Lack of power and MPG @ 13-14 suddenly help
"my car drives like it has a sock in the intake"
Also, the MAX I can get my throttle open is roughly 72%.
Well if your throttle is not opening wide that would be like having a sock in the intake!
Maybe your traction control servo is preventing full throttle either because it is broken or under control of ecm/tcm and maybe that is a
result of something happening in the gearbox?
No codes, I think that the coil packs I bought from these guys in November may have reached their point of diminishing returns perhaps?
http://www.buyautoparts.com/buynow/1...ml?xref=228228
I seriously can't figure anything else out....
1997 Jaguar XJ6 Ignition Coil 4.0L Engine 32-80130 AN
You might also try pulling one coil to see what code comes up, if any. Also, maybe pull them all out and clean them (oil?).
Padre
#28
They are clean. The Jaguar doesn't do the best at identifying the culprit via the computer too well. I have the originals and will swap back tonight. The company I bought them from (who claim to have great customer service and a 1 year warranty) want me to pay to have them tested at the dealer!?
Received 2,650 Likes
#30
#31
#32
i see in the first post you had the MAF tested
why not just try a new/secondhand one? (part LHE1620AA)
Assuming you have a N/A car, they are easy to come by (XJR AFMs are not easy (LNA1620AA) - I am struggling to get another genuine used one at the moment)
It just might be the MAF - no promises, but easy to swap in and see
#34
Given the amount of money it sounds like you have spent, getting a used MAF and swapping it out seems worthwhile to me. I did that when I had a problem (that was resolved with a new crank sensor) and it eliminated the MAF from the equation. Testing is one thing, in use is another.
I think it's OK to run the engine with the O2 sensors disconnected (although check first) - maybe that would tell you something? My local mechanic did that on his own car when it was playing up and its performance perked up a lot, but it was some crappy euro box.
However, surely you should address the fact that your throttle only opens to 72% That is a clear fault and without eliminating things you know are wrong you could be in danger of wasting time an money.
I am following this thread with great interest but I'm glad it's not me.
#35
#37
Is the operative word here not the "suddenly" which appears in your title to the thread?
Going back to first principles, it is worth retracing your steps just before the "suddenly" moment to look for clues. You havent provided much information beyond the fact that you used some form of additive made by Chevron. How have you been able to eliminate that as the possible cause? As I said earlier, I am not familiar with the additive in question, and hence don't know how it is administered or what it is intended to do, but it would seem to be something of a smoking gun in this mystery.
When you are trying to accelerate, and the car feels like it has a sock in the intake, I am taking that literally, ie that it is not misfiring, running rough etc ? Is there any visible exhaust smoke?
#38
We don't have that Chevron additive in the UK but I did find a review on Amazon US that said they too suffered an mpg loss after using it as well as some posts saying it 'wrecked their engine'. Apparently you can over use it but it's also an additive they put in their fuel anyway. Most reviews are very positive and the Aston Martin forum recommends it.
#39
#40
Just a shot in the dark. Could it be possible that your injectors are partially blocked? I am thinking your additive may have clogged things up allowing enough fuel for smooth idle but not capable of delivering enough fuel when demands are increased. Could this also keep the injectors from delivering a proper atomized spray of fuel and just dumping fuel into the cylinder, leading to unburned fuel, thus the poor fuel mileage.
