Leak below the oil filter, Oil cooler?
I have a leak just below the filter on my 96 XJ6 VDP. I think it’s either a part of the oil pump or cooler housing.
I tightened the nut and it slowed the flow but, I know it needs to be re-sealed. Do any of you know if it is a gasket of simply uses RTV sealer?
Thanks for your time to reply.
Quietgiant (04-21-2021)
The following 2 users liked this post by Parker 2:
motorcarman (04-21-2021),
You have a good eye. I saw that too and gave it an added twist ( was not tight) then tightened the mounting bolt for.the cooler. Cooler bypass still drips 3x a minute under pressure. I’ll attack it and a few other deferred maintenance items in a day or so. Thanks for the input! Also thanks to Parker for the link.
Grant Francis (04-23-2021)
Aholbro 1 had a picture write up on replacing them and there was a trick I believe i think it had to do with the square portion
Found it
https://www.jaguarforums.com/forum/x...l-pics-160138/
Found it
Grant Francis (04-23-2021),
Quietgiant (04-22-2021)
The following 3 users liked this post by motorcarman:
just one
Its a super simple job, and you only loose about 1dl of oil when pulling the bypass, so no need to wait for the next oil change to do it.
I would recommend having a sharp knife ready to cut the old o-rings though, as they are often hard like plastic due to age.
Parker 2 (04-23-2021)
motorcarman (04-23-2021)
this is an alternative to just replacing the o-rings on the horseshoe.
Quietgiant (04-23-2021)
dhatfield12
XJ40 ( XJ81 )
21
10-29-2016 07:43 AM
NJ2003XJ8
04-27-2016 09:08 AM
