Leaking starter fluid!!!
I have a 97 xj6 with an oil leak that appears to be from an o-ring on a galley plug behind the adapter plate for the trans.
I plan on tackling this job but want to make sure I have all the required parts before I start. The diagrams I can see show little of the back end. Is this oil galley threaded or do I have to punch it out and replace? Am I barking up the correct tree? Any help help would be appreciated.
-Neil
-Neil
The gallery plugs are threaded, one in the rear, as you mentioned, one in the front, under the timing cover.
Part # EAC2494. Look like an allen key for R&R.
I have not heard of them leaking, but anything is possible I suppose.
Most AJ16 oil leaks are from the top, and run down and appear to be from somewhere else. The "D" seals, part of the camcover gasket assembly are notorious.
Don B (05-03-2020),
nunger1330 (04-21-2020)
A leak from that plug seems to be rare but has been known.
See this thread from @Qvhk
https://www.jaguarforums.com/forum/x...engine-194333/
The following 5 users liked this post by b1mcp:
Don B (05-02-2020),
GGG (04-24-2020),
Grant Francis (04-21-2020),
nunger1330 (04-21-2020),
Qvhk (04-24-2020)
Thanks guys that was exactly what I was looking for! I already changed a lot of the parts that was listed in that thread including the oil pressure sensor, the gasket I ordered had integrated "D" seals to boot and still have the same problem... I guess it is time to get ready to remove the trans and go for the o-ring. Parts are ordered and should be here in about a week. Ill post a pic of the back with the plug when I get to swapping it. As always thanks for the help.
The following 4 users liked this post by Qvhk:
Figured I’d update. I got the tranny, and adapter plate out today. The galley plug is threaded and does not have an Allen key. It was getting dark and I didn’t have the right bolt for the plug so I called it. Still not too sure how the thing comes out yet. Hopeing to hit it again in the next few days.
as promised below is a pic of the plug.
Here is the leaking galley plug.
-Neil
-Neil
The following 4 users liked this post by nunger1330:
The following 5 users liked this post by nunger1330:
b1mcp (05-04-2020),
Cafcpete (05-04-2020),
Don B (05-03-2020),
littlelic69 (05-04-2020),
marke (06-14-2021)
-Neil
-Neil
-Neil
-Neil
Also, is there anyway to get there without disconnecting the transmission?
Parker 2 (06-16-2021)
-neil
thaddeus333
01-06-2015 10:03 AM
