Leaking trans fluid after sump gasket change
This was the thread I posted about the same issue a few years back
https://www.jaguarforums.com/forum/x...rchase-119923/
You don't necessarily need to replace the gasket. I did an oil and filter change and thought I would need a new trans sump gasket. I bought two gaskets, the first was the wrong shape because the Jag version of the 4L80e has a slightly different case to the GM version, and the second was the right shape but was obviously of inferior quality to the original so I chose not to use it.
The original gasket as you mentioned has a rubber O-ring-like seal right around it and the bolt holes have steel inserts. My old one looked ok so I reused it and it does not leak at all.
Be careful that the bolt hole threads and bolts are clean and don't overtighten the bolts as the case thread will easily strip, and then it probably will leak.
By the way, what colour is your trans dipstick handle (mine is red)?
oldish git
27
07-24-2020 02:05 PM
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
jetjack
04-11-2016 02:46 AM
