LED Lighting for Dashboard & Centre Console
Old 01-10-2015, 11:16 AM
dfieldsend's Avatar
Default LED Lighting for Dashboard & Centre Console
Many f my bulbs were out, so thought I'd do the "Blue LED" thing, plus fix the clock with a new ribbon cable...
... Here are the results
Attached Thumbnails LED Lighting for Dashboard & Centre Console-img_2470.jpg   LED Lighting for Dashboard & Centre Console-img_2462.jpg   LED Lighting for Dashboard & Centre Console-img_2435.jpg
The following 3 users liked this post by dfieldsend:
Don B (01-12-2015), MountainMan (02-17-2015), XJRay (01-12-2015)
Old 01-11-2015, 06:42 PM
MrVictamone's Avatar
That is very nice, I thought of this same idea some time ago, but thought that with the age of the system that the LED's wouldn't work out well with it. I'm glad to be proven wrong. Did you have to replace any fuses or relays to do this work?
Old 01-11-2015, 07:41 PM
FrozenApple's Avatar
nicely done, what kind of led are u using? and what resistor did u use?
Old 01-12-2015, 07:37 AM
dfieldsend's Avatar
I used these, didn;t need a resistor and they also are dimable using the standard dimer control on the steering column.
I took them apart and mounted then in the various other holders so I had a standard colour across all the dash
10PCS DC 12V T4.2 LED 3528 SMD Car Blue Dash Board Cluster Gauges Lights Bulbs | eBay
The following 2 users liked this post by dfieldsend:
ccfulton (01-12-2015), rod_f (01-18-2015)
Old 01-12-2015, 09:08 AM
mgb4tim's Avatar
How many bulbs did you end up using?
Old 01-12-2015, 03:50 PM
dfieldsend's Avatar
About 60 in total - needed a few white and red ones for hazard warning switch etc
mgb4tim (01-13-2015)
Old 01-12-2015, 07:00 PM
NTL1991's Avatar
Are the same bulbs sizes used for gauge backlighting and the warning lights?
Thanks,
Nick
Old 01-13-2015, 12:12 PM
dfieldsend's Avatar
Yep - same bulbs for all for consistency.
I even used the same ones for the bulbs in the door window switches
Attached Thumbnails LED Lighting for Dashboard & Centre Console-img_2421.jpg   LED Lighting for Dashboard & Centre Console-img_2446.jpg
Old 01-14-2015, 08:10 PM
al_roethlisberger's Avatar
Looks good, I may do something like this at some point, but would be interested in getting the needles to still show as white.
Old 01-15-2015, 02:07 PM
mgb4tim's Avatar
I haven't torn into mine, but I would guess there's a lamp near the pivot base of the needle because of how brightly all the needles are lit.
Old 01-15-2015, 02:34 PM
dfieldsend's Avatar
Its a clear plastic "light tube" type thing, but the same bulb is used to iluminate the needle aswell as the dial - already working on the 2nd gen version with a slightly funkier design, will post when I've done...
Old 01-15-2015, 02:35 PM
I think the problem is that all of the original lights are white, and the gauge pack "filter" is what turns the numerals, etc green & red. So using any colored LED ends up coloring the needles as well.
Old 01-18-2015, 05:28 PM
rod_f's Avatar
Is there any consistency over which is the positive feed to the bulbs ?
ie - upper, lower, left, right ?
Obviously it didn't matter with incandescent bulbs so it could well be random but it might save taking the unit in and out several times.
Can't quite remember the pcb clearly even though I replaced a stock bulb recently.
Old 01-18-2015, 06:06 PM
Here is the somewhat "definitive" LED conversion thread for the XJ6:
https://www.jaguarforums.com/forum/x...dimming-38712/
... has a lot of info along the lines of your question.
Old 01-30-2015, 12:54 PM
dfieldsend's Avatar
OK so Version 2 is now complete - multi coloured LED's
Fibre optics to spot light the dial ends, and even changes colour when you put it in "Sport Mode"
Attached Thumbnails LED Lighting for Dashboard & Centre Console-10940426_925753634116383_2848688530312060377_n.jpg   LED Lighting for Dashboard & Centre Console-10423671_925753657449714_1845734660874411543_n.jpg   LED Lighting for Dashboard & Centre Console-img_2512.jpg
Old 02-01-2015, 11:55 AM
Version two (I assume second photo with green lighting) looks good.
Do they dim as well?
Any additional detail of how you built the "fiber optics" to get light to the needles, etc?
Old 02-01-2015, 12:51 PM
dfieldsend's Avatar
No all of these pictures are of version 2, the dash is normally in blue with red dials, but when you press the sport button near the j gate, the dash goes green.
Old 02-13-2015, 08:20 AM
BlackXJR's Avatar
Thumbs up
Very cool! Care to expand on how you made all this work? I have my cluster out right now to install the trim rings around the gauges and would be interested in doing this...
simo5555
09-09-2015 06:22 AM
Saturbo
09-08-2015 07:35 PM
sklimii
09-05-2015 06:04 AM
bdboyle
09-04-2015 06:16 AM
XFR_Gold
09-02-2015 12:24 PM
Quick Reply: LED Lighting for Dashboard & Centre Console
