Left rear door won't open using inner/outer door handle
I've searched this forum for a solution, but can't find anything similar to my scenario ... if there is a post someone knows of, please point it out. Otherwise:
Not long ago, I pulled on the outer door handle to open the left-rear door and the door didn't open. I opened the right-rear door, reached across to pull on the (left rear) inner door open handle - door won't open.
After pulling on the outer door handle a number of times (in the hopes of getting the door to open), the handle is now very loose and a simple flick of a little finger can pull on the handle - it's obviously completely disconnected from the door latch mechanism.
The inner door-open-handle still works. Check the following image - when I pull on the handle, the cable pulls as expected on the piece that the red arrow points to and it rotates, but the door will not open. I've fumbled around with my fingers in that area to unlatch the door, but nothing gives. That piece that rotates obviously must "push" against the un-latch mechanism, but doesn't.
Any ideas?
Any ideas?
![](http://img838.imageshack.us/img838/7708/reardoor2.jpg)
I've checked the shop manual to see how the door [un]latch mechanism works, but there isn't any detail or graphic showing how it works.
Your problem might be with the electric locking module (in the door).I have had the same problem and the locking button would rise then go back down,I soaked the unit with wd40 and held the locking button up with a pair of pliers then used the inside handle to open the door. Once open i checked the child safety unit to make sure it was working corectly (it was). It worked well for about a week then the problem returned,I then changed the electric module and it has worked fine since then. I believe there is some corrosion inside the module that was causing the problem.
The locking mechanism fully unlocks as it should. To be sure, I pulled up on the knob fully ... it's fully unlocked, yet the door won't open. I may open up the right side rear door panel to see how the door-open mechanism is supposed to work.
One thing i haven't done ... i should check the microfiche i have for the car to see if there's a parts figure with the mechanism in an exploded view.
BrentGardner
28
04-26-2024 03:08 AM
Pristine97XK8Convertible
09-29-2015 02:43 AM
Andrew McVey
16
08-27-2015 07:21 PM
