LNAAAA4144AB Harmon Kardon Rear Subwoofer Theoretical Replacement.
While doing other projects I pulled out and tore apart my old broken LNA4144AB rear sub (which I replaced with a used OEM speaker) and measured the ohms/impedance values (which I cannot find cited anywhere.)
This is a thread for the benefit of others, and my future benefit if my 2nd rear sub ever blows.
Each coil on my rear sub measure at just about 5 ohms. I suspect a 6x9 with dual 4-ohm coils would suffice just fine, or two 4-ohm subs if the rear deck could be made to fit a left and right speaker.
As it so happens there now appears to be a couple of nearly direct replacement for as little as $75 with 2x 4 ohm connector sets on one speaker:
RetroSound R-69N DVC Dual Voice Coil 6x9" 200 Watts-Upgrade Replacement Speaker
https://www.retromanufacturing.com/p...ant=7981134403
DVC Speakers
In-Dash Replacement Speakers
Perhaps there are others, but maybe this will help somebody.
Paul Kobres
96' VDP
DVC Speakers
Paul Kobres
96' VDP
The following 4 users liked this post by FerrariGuy:
Thanks ![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
Also, these threads have some info on alternative options for the rear dual-coil 6x9 subwoofer. A search of the X308 forum turns up a lot. Seems like the X308 crowd is working on this issue more than X300 owners, probably because there are lot more X308s out there.
https://www.jaguarforums.com/forum/x...thread-168335/
https://www.jaguarforums.com/forum/x...cement-159588/
And of course, one can easily replace the rotted surround (which is what fails) for about $5-10 as I recall with a kit.
FerrariGuy (05-24-2017)
Another option that *looks* viable is to use a Harman Kardon 6x9 R53 R50 speaker from a mini-cooper. They pop up on ebay and seem to be connected similarly as the Jag speakers:
OEM:
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/448x336/img_1340_f1327b19753a93c9e28e49c8193d39b57bbca8f8.jpg)
![](https://cimg0.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/448x336/img_1341_eb4eeaf6b9621c8aed5a9cba7137de9b5d805b8a.jpg)
VS:
02-06 mini cooper s R53 R50 left right rear speaker Harman Kardon 65136801095 .. | eBay
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/500x333/s_l500a_0f519ee08d305961d0553e6f3237c6efdd5f641a.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/500x333/s_l500_0bb7555cd6209ea424d0fba5da24fa67b73d6769.jpg)
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/500x333/s_l500b_de9d9037b6424feb9a61c704124cb2f323898599.jpg)
doriel
10-11-2016 08:12 PM
