Location of chassis number(s)
I seem to recall some time back on this forum that there are two locations for chassis numbers, one in the boot (trunk) next to the battery and another somewhere in the engine compartment. I can find the one at the rear, but for the life of me I can't locate the front one.
Can someone please tell me where it is?
Thanks.
Thanks.
A mechanic told me this was the case in all vehicles to help detect if two cars have been cut in half and joined in the centre, making one.
Thanks again.
From the couple of replies it seems I am mistaken about a chassis number also being metal stamped somewhere in the front engine compartment. Although I'm pretty sure it was said previously on this forum.
If, as I've been told, it's 'insurance' against the chance of two ends of a different vehicle having been joined together, then it would be pretty straightforward for an unscrupulous person to replace the side window if that was where it was situated (in addition to one at the base of the windscreen).
Aside from the one stamped in metal on the windscreen I found VIN # labels on most of the major body panels. On my boot there is one on the lid as well as in the groove running around the boot. The drivers side doors also have them. I have them on the front and rear bumpers also. The manual that I have says there are some on the bonnet but i don't have any there. Strange now that I think about. The only one metal I can find is the one on the windscreen. The manual does say USA only so if you are elsewhere i guess these dont apply.
Thanks for that, but none of the above can be described as locations for 'chassis numbers' which are, by definition, stamped on to the chassis. All the parts referred to are removable and can be replaced, often for very legitimate reasons - eg; accident damage.
The whole point of chassis numbers is that they cannot be replaced by removal of a body part or panel.
Manufacturers stamp front & rear to prevent the unscrupulous individual from taking front & rear sections of accident damaged vehicles and welding them together as one.
I'm 99% sure my vehicle will have locations front & rear for such numbers, I know where the rear one is, it's stamped in to floor of the boot. But where is the front one?
Thanks again.
scooternva
20
09-27-2023 11:25 AM
Gatsby
09-06-2015 11:52 AM
KarimPA
09-03-2015 07:32 PM
