Looking for Help...
OK, then, I would say there is always the possibility of a bad sensor, but it would seem unlikely. I would have a good look at the CKPS connector for corrosion, clean it with some contact cleaner or alcohol, then get in the right front kickpanel, remove the ECU connectors and have a careful look there for corrosion.
The 5 hours good running is probably NOT a coincidence- or is it?
dmpsqrd (03-26-2016)
Look carefully at it first (magnifying glass?). Then spray away. You are looking for corrosion or the spring connectors to be misshaped. You should measure the resistance of the CKPS. No meter?, Harbor freight has one for $6.00, or free on some promotion days.
The ecu connectors are a PITA to get to, but definitely worth having a look. Many folks are reporting corrosion there these days.
mhessen6
01-04-2018 09:16 PM
