Low beams went out. Not the bulbs. fuses.
The low beams randomly went out but right before it went out i was slamming my sub super hard. and even before they blew if the base was up the lights slightly flickered...anyone else have this happen?
well im thinkin i blew a fuse. does anyone know what type fuse the low beam is on a 1997 jaguar xj6 thanks!
alohaz
alohaz
should be a fuse box under the hood on the left side as you're loking at the car. There also should be a diagram in the fuse box lid as to which one it is. There are replacements in that same box for all different amp levels. Gotta watch the use of the heavy adio electronics like amps and subs. The x300 stock wiring really isn't set up to handle the power draw some of those things demand.
Ben
Ben
rsa760041
23
09-25-2015 01:33 PM
