Low octane/codes?
Received 10,871 Likes
Those are cat converter efficiency codes. Offhand I don't see how octane rating would play in.
I'd stay with manufacturer recommendation but if you wanna experiment your car has knock sensor which detect knocking/pinging...which might well result from the lower octane... and automatically retard the ignition timing to eliminate it. As a result you might feel a loss of power and use a bit more gas.
If you are a very gentle driver and conditions are ideal you might not get any pinging or knocking
The reason why I asked was because someone borrowed my car and put in 87 or 89 octane and it was throwing a P0420 and P0430 code. I filled it with premium fuel today and cleared the codes right after. Drove her about 50 miles and no codes so far. And yes,I'm a fairly gentle driver when it comes to my Jags.
