lowering my vdp
lowering my vdp
im really wanting to lower my jag for looks and also better suspension. what springs are good and not sacrifice the ride comfort as much? while getting springs i might as well get struts and dampers but i know nothing about struts or dampers what kind would i need? ive looked through mina gallery whats another good site to get jaguar parts?
Received 10,952 Likes
Stay with the 18s. Going larger just starts looking plain goofy on a Jag. Just my lousy opinion, of course, as I've never understsood the fascination with the big-Bigger-BIGGEST wheels thing :-).
why such a shame in lowering a jaguar? because it sacrifices of the luxurious comfort of the jaguar? dougs is it that big of a sacrifice to you? it still has top of the line interior and one and only jaguar exterior that not even hyundai can try to copy. i think a jaguar lowered a little bit with 18s would be perfect.
Taste aside, if you read enough posts by owners who have lowered various Jaguar models, you will see a common complaint: the car cannot be aligned correctly to avoid increased front tire wear. On your model there is no adjustment for front wheel camber, and the negative camber induced by lowering it cannot be compensated for. If chewing the inner shoulders off an expensive pair of front tires is not something that concerns you, then outfit the car the way that it pleases you most.
someguywithajag (12-31-2020)
Doug
not to mention 20"s would rub like hell.
I've got some 18"s off a younger XJR and even they rub a tiny bit on full lock.
Also I've never seen lowering springs for sale specifically for an X300. I've seen them for X308's, but never for X300's.
Also Jagtech is correct in that the camber will forever be off no matter how you do it; spring clamps, cutting sections off, whatever, since there isn't the adjustment for it.
I searched the ends of the earth looking for ways to lower my XJ6, just because I love the way slammed cars look.
Guest
Posts: n/a
Lowering Springs H&R
Hi!
There are lowering springs available for the X300 from H&R.
Partnumber: 29576-1 for X300 all from 11/1994 to end
http://cgi.ebay.de/H-R-Federn-Jaguar-XJ-Typ-X300-1994-40mm-29576-1_W0QQitemZ360055117739QQcmdZViewItemQQptZAutoteil e_Zubeh%C3%B6r?hash=item53d4f517ab&_trksid=p3286.c 0.m14&_trkparms=72%3A1229|66%3A2|65%3A12|39%3A1|24 0%3A1318|301%3A1|293%3A1|294%3A50
aholbro1
08-05-2021 05:02 AM
FS[Western US]: 2001 Jaguar x308 VDP SC Catalytic Converter Housing
perezal
12-24-2015 04:16 PM
